Emby Server update suggested on Terramaster F2-210
janlukemam1
Post by janlukemam1 »
Hi all,
I manually installed Emby 4.5.4 on a clean Terramaster F2-210 NAS environment and everything went fine so far.
Today I found on my TOS that there's an update for my Emby Server App so here are two questions for you:
  • why TOS is reporting Emby Server as 4.5.2.0 even if I manually installed versione 4.5.4.0?
  • since no newer version of Emby should be released, am I supposed to run this update?
Here's a screenshot of the situation:
Thank you
Re: Emby Server update suggested on Terramaster F2-210
The 4.5.2.0 is to display the version of Emby on the TOS Application Center server.
After you click update, it will change to 4.5.2.0.
janlukemam1
TMRyan wrote: 26 Mar 2021, 17:58 Hi,
Thank you for your reply TMRyan,
since I manually installed v 4.5.4 I won't run the update then.
One suggestion: please load on TOS App Center v 4.5.4 as soon as possible, since it's a big improvement in comparison to 4.5.2 .
Return to “Plex Media Server”
