Docker repo auth
Discussion about Docker
noller1
Docker repo auth
Post by noller1 »
Installed latest version for F2-210. There is currently no method to authenticate to the repo for downloads. Repo's load but nothing will download. Any plans to fix this?
Re: Docker repo auth
I can't understand your question. Can't you download images from Docker?
If you cannot download, please wait for a while or download another one.
Can't set up the docker repository? Maybe you can search for related answers from the Internet.
1dimitri
Post by 1dimitri »
TMRyan wrote: 26 Mar 2021, 11:53 I can't understand your question. Can't you download images from Docker?
There are 2 ways to download images from Docker's repository:
- anonymous with some time/number of images limitation since the latest docker.com rules have been published
- by using a registered account
The Docker package does not provide a way to input credentials
djonesuk
Post by djonesuk »
The built-in Docker app is a great way to get started but I suggest moving to Portainer if you want more granular control.
https://documentation.portainer.io/v2.0 ... alldocker/
Return to “Docker”
