VirtualBox Flash Plugin Dep.
noller1
Post by noller1 »
Currently have latest VBox installed on my F2-210 and it is still requiring Flash plugin to render console which is depreciated and no longer available. Any plans to update?
Re: VirtualBox Flash Plugin Dep.
F2-210 does not support installing VirtrualBox from the application center.
Did you install it using Docker?
You can use the remote connection directly or use the Firefox browser to install the Flash plug-in.
Return to “Virtual Machines”
