D5-300 USB No longer recognised!
Shadeena
Post by Shadeena »
I have a D5-300 set up with 5 Drives in RAID 5 format and have been using for almost two years without any problems. As of this afternoon, the Drive is no longer recognised by Windows but the Terramaster RAID Manager says that all drives are normal and working well. Any advice?
Re: D5-300 USB No longer recognised!
The RAID hard disk information can be seen in the RAID Manager software to prove that the product is no problem.
Please open the computer disk management to check whether the disk has partitions and whether the partition file system is damaged.
You can try to restart the computer and TDAS, or reinstall the driver and software.
Shadeena
Post by Shadeena »
Thanks. Partition got fried even tho all drives are healthy, problem fixed using Easus software
May I know what's your meaning of "Partition got fried" ? Thank you!
Return to “USB Series”
