I'm going to buy a d5-300c product, will WD Ultrastar DC HC550 18 TB be compatible?
typhoon0702
Post by typhoon0702 »
I want to buy three and use two as Raid 0 and the other one as a hot spare.
thanks in advance.
Re: I'm going to buy a d5-300c product, will WD Ultrastar DC HC550 18 TB be compatible?
Our equipment is compatible with SATA interface hard drives, and the latest 18TB hard drives are supported.
We will update the official compatibility list: https://www.terra-master.com/global/compatibility/
If you want to use the third hard disk as a hot spare disk, you need to create Raid 1, and you need to replace it manually when one of the hard disks is damaged: https://support.terra-master.com/faqs/t ... h_a_D2_310
TooBreezy
Post by TooBreezy »
I am looking at getting an Ultrastar drive as well, are there any differences between the 18tb and lower Tb models? I wanted to make sure, if the 18 is compatible, shouldnt the 10tb or 12tb be as well?
Return to “USB Series”
