- Move a folder from one Terramaster NAS to another Terramaster
Rename a folder
Reconfigure a folder to shared
Newbie and stuck
Newbie and stuck
How on earth do I do these:
- sianderson
- Silver Member
Re: Newbie and stuck
i'm sure theres plenty of ways to do things, but i guess my question would be is it just a one off process? and how much data is involved?
you could use a PC as a go between and just transfer it across between two network shares,
you could back it up to usb on one, plug in to the other one and copy and paste it via the filemanger etc
i believe you can mount a NFS within the filemanager from one nas to the other and copy that way but i have no practical knowledge of this
F2-424 TOS 7.0.1278
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
If you want to move the folder from TNAS-A to TNAS-B.
You can create a new folder on TNAS-B, then go to the control panel to enable the Rsync server, and add the backup destination shared folder to the authorized directory. Then use the Rsync Backup of the TNAS-A desktop to create a backup task.
