Unable to bind ports 443 or 80 to docker container
matt_30
Post by matt_30 »
I appear to be unable to bind ports 443 or 80 to any docker container.
I am unable to see any application using these ports.
Is there any process the TNAS uses which reserves these ports?
I'm planning to use these to point to docker containers.
TMS
Re: Unable to bind ports 443 or 80 to docker container
Post by TMS »
Port 80 is occupied by the web server and port 443 is occupied by the system, none of them can be used elsewhere
matt_30
Post by matt_30 »
Thank you for confriming.
What does the system need 443 for?
Can this be moved? This is impacting the ability to run many containers.
TMS
Post by TMS »
Port 443 is used by TNAS PC to search for TNAS device address and cannot be moved.
matt_30
Post by matt_30 »
Is there any reason why you have selected the most commonly used port for your discovery app?
You have almost 50,000 ports you could have used but blocked the one most commonly needed for many applications.
Applications like SWAG, Nextcloud or anything which requires SSL cert generation requires this port.
Can you please change this port in your next build as you are seriously limiting the capability of your product.
Return to “Network”
