Strange app overload CPY
unixtall
Post by unixtall »
My CPU is always near 100%. Which is that?
Re: Strange app overload CPY
I can't see the 100% picture of the cpu you sent, you can send it as an attachment.
Is it possible to let our engineer check it remotely? You can send an email to our tech team :viewtopic.php?f=75&t=608
sianderson
Post by sianderson »
that sort of process name is usually malware running on your nas drive so i believe you are infected with something
if you know what you are doing you can SSH to the nas drive and then prevent it from running, but more than likely you will either need to wipe your drives and start it all again or allow a TM engineer to login in remotely and they may be able to prevent it from running at start up
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
unixtall
Post by unixtall »
How can i see the process that starts with the system? Or if there is a process that start with a timer. Its seems to be a malware. When i kill the process, CPU is ok.
TMS
Post by TMS »
Is it possible to let our engineer check it remotely? You can send an email to our tech team : viewtopic.php?f=75&t=608
unixtall
Post by unixtall »
My hour is gmt+1 its so difficult that your engineer check it.. :(
I see a suspicious process: vinu3imu0jdg3ma
See the captures. Is normal that?
This is abnormal. After you send the email, we will arrange a reasonable time to solve it for you remotely.
Return to “System Resources”
