Port 80
vkpk
Port 80
Post by vkpk »
I'm running TOS 4.2.X and I need to use port 80 for a reverse proxy that I run in docker. This port is used by the system, but I don't see what for as the TOS web UI is accessible on :8181 and :80 seems to re-direct to :8181. This is wasteful and forces me to use a custom port number in the web services I run locally.
Can you please let me know how to release port 80 and why do you need to use port 80?
Thank you
Re: Port 80
Port 80 has been designed for web server, you cannot release this port, you need to use other ports to configure reverse proxy.
If your machine is not FX-210, you can try Nextcloud in the application center.
