Latest Plex Update Broke It
BigDad
Post by BigDad »
Yesterday I updated the Plex app to version 1.21.4.4079 on my F2-210 running TOS version 4.2.08-2101111540-P1.04. Today I find a viewing process (Photos) hung and it cannot be cancelled. So I clicked the Reset button. After churning for a while and finally quieting down, I can access the Plex server via the management console, but the server contents stay Unavailable to any client, including the management console.
Any advice?
TMS
Re: Latest Plex Update Broke It
Post by TMS »
Can you take a screenshot to illustrate the problem?
sianderson
Post by sianderson »
i know it isnt a very helpful comment but its constant issues with plex like this that i stopped using it and changed to just use DLNA Media Server, all my content are MP4's which are compatible and i only wanted internal viewing on TV's in the house, i havent had a single issue since using it but plex was nothing but trouble with updates and sync of content etc
so i would think about whether you really need to run plex or not
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
TMS
Post by TMS »
Does have some problems after Plex is updated?Can you give me an example(often appear)?
BigDad
Post by BigDad »
Attaching a screenshot of Unavailable libraries...
To sianderson, the only reason I'm using Plex is because the built-in DLNA server is too fragile to handle over 57,000 music files. I agree that Plex is challenging to manage.
BigDad
Post by BigDad »
...and now the Plex app shows 2 servers by the same name (Northwoods_NAS). One has no content available, the other has the original content, but most of the metadata for everything but movies is gone (album art, etc.).
V8Triker
Post by V8Triker »
I had a similar issue, and it was due to Plex defaulting to "Secure Connections Required"
If you set it to preferred, it should resolve you issue.
I only found out 'cos a message box popped up, in Plex, asking if you want to make it less secure so you can access the media.
I think it is because the TNAS is not providing an HTTPS connection.
My Ubuntu server, which I am moving my Plex server off, has an SSL certificate.
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
TMS
Post by TMS »
{L_BUTTON_AT}BigDad
As screenshot : unable to connect to the server, the original database connection fails
You can reset plex and add new media library
BigDad
Post by BigDad »
I tried Resetting Plex earlier and that's when the 2nd set of libraries showed up. I also uninstalled Plex, rebooted the F2-210 and then installed it again, but nothing changed: still have 2 sets of libraries, one is unavailable and the other looks like a rebuild was incomplete, due to missing metadata. Per your instructions, I started another Plex Reset 20 minutes ago. The disk drives rattled for a bit as it started the rebuilding process, but the noise soon stopped and the CPU has been hovering at 4%-7% ever since. Plex app status still shows "Configuring..., please wait!"
I'll let it run a while longer, but I'm beginning to think I need to nuke Plex, restart TNAS, clear its files and cache without affecting the media files (need help with this), and then install and configure it again.
Thoughts?
TMS
Post by TMS »
Please try the second method of this link to troubleshoot viewtopic.php?f=75&t=364
