dynv6 don't work
DenisJosifoski
dynv6 don't work
Post by DenisJosifoski »
Hello TerraMasters ;)
I found that dynv6.com DDNS don't work. Everytime I want to enable it and apply, it refuse to do it. Anyone else tried dynv6 and have similar problems?
Family member || Friend || Filmmaker || Youtuber
In exact order. I also can’t survive a day without a Latte macchiato!
https://www.denisjosifoski.com
DenisJosifoski
Re: dynv6 don't work
In case if anyone else comes into this with dynv6.com, here is the solution:
Click on your email arrow, then click on keys. Generate TSIG key, click on details after and use 'secret' code as username, password is the one that you use for login to dynv6.com ;)
akson
Post by akson »
ick on keys. Generate TSIG key, click on details after and use 'secret' code as username, the password is the one that you use for login to dynv6.com ;)
Latte
jing
Post by jing »
fast
Western67
Post by Western67 »
I found that dynv6.com DDNS don't work. Everytime I want to enable it and apply, it refuse to do it. Anyone else tried dynv6 and have similar problems? :D :D
track
Make sure your credential is correct.
Return to “Network”
