Loss of Samba/CIFS mount on client
kilbey1
Post by kilbey1 »
I am running TOS 4.2.09-2101251735-P1.04 on an F2-220.
I find t that after some time, the client on which my NAS folders are mounted (a Macbook) runs into a connection error and loses the mounts.
Running Macbook 16" 2019 with Big Sur 11.2.3 (20D91).
When the mounts are lost, I find I can still ping the NAS.
After connectivity is lost, I log into TOS and may see the Samba file server as disabled. I try to restart with the TOS user interface, but it does not succeed. The UI shows an attempt to connect, but the checkbox refreshes to unchecked.
Checking the service from the Service Status panel shows that Samba is disabled.
I SSHed into the NAS as root and ran a Samba restart command, then Samba start command, and the following is returned:
[root@musicinas ~]# /etc/init.d/samba restart
Reloading smb.conf file: killall: smbd: no process killed
killall: nmbd: no process killed
0
0
start-stop-daemon: unable to close pidfile '/var/run/samba.pid' (No space left on device)
start-stop-daemon: child returned error exit status 2
/etc/init.d/functions: line 611: echo: write error: No space left on device
[root@musicinas ~]# /etc/init.d/samba start
0
0
Checking my space shows Used Space 5.37 TB, and Free Space 3.72 TB.
At this point, the only option is to restart the NAS completely. I usually have to restart the NAS about 2 or 3 times a day.
Re: Loss of Samba/CIFS mount on client
Your system does not have the configuration file, you need to reinstall the system:viewtopic.php?f=75&t=423
kilbey1
Post by kilbey1 »
Do you mean the Samba files? I see I have it.
[root@musicinas ~]# cd /etc/samba/
[root@musicinas samba]# ls
buildhome  lmhosts.rpmorig  smb.conf          smb-extend.conf  smb-null.conf
lmhosts    smb-ads.conf     smb.conf.rpmorig  smb-ldap.conf    smbp
smb.conf:
[global]
include = /etc/samba/smb-extend.conf
[homes]
comment = Home Directories
path = /mnt/md0/User/%S/home
root preexec = /etc/samba/buildhome %D %S
valid users = %S
browseable = no
writable = yes
veto files = /desktop
[public]
path = /mnt/md0/public
browsable = yes
writeable = yes
inherit permissions = yes
public = yes
use sendfile = yes
aio read size = 4096
aio write size = 4096
[appdata]
path = /mnt/md0/appdata
browsable = yes
writeable = yes
vfs objects = catia fruit streams_xattr
fruit:time machine = yes
write list = admin,evemcgivern
valid users = admin,evemcgivern
use sendfile = yes
[Video]
path = /mnt/md0/Video
browsable = yes
writeable = yes
use sendfile = yes
[Photo]
path = /mnt/md0/Photo
browsable = yes
writeable = yes
use sendfile = yes
[Music]
path = /mnt/md0/Music
browsable = yes
writeable = yes
public = yes
hosts allow = *
hosts deny = 0.0.0.0/0
use sendfile = yes
[usbshare1]
path = /mnt/usb/usbshare1
browsable = yes
writeable = yes
write list = evemcgivern,admin
valid users = evemcgivern,admin
use sendfile = yes
smb-extend.conf:
[Global]
allocation roundup size = 4096
passdb backend = smbpasswd
obey pam restrictions = yes
encrypt passwords = Yes
max log size = 100
socket options = TCP_NODELAY SO_KEEPALIVE SO_SNDTIMEO=10 SO_RCVTIMEO=10  IPTOS_L
config file = /etc/samba/smb.conf
smb passwd file = /etc/samba/smbp
smb encrypt = off
strict allocate = no
durable handles = no
min protocol = NT1
max protocol = SMB3
client min protocol = NT1
client max protocol = SMB3
log level = 0
guest account = guest
delete veto files = yes
follow symlinks = no
wide links = no
unix extensions = no
min receivefile size = 4096
client ntlmv2 auth = yes
client lanman auth = yes
ntlm auth = yes
lanman auth = yes
local master = no
os level = 200
smb2 leases = yes
netbios name = musicinas
server string = musicinas
workgroup = WORKGROUP
veto files = /.AppleDB/.AppleDouble/.AppleDesktop/Network Trash Folder/Temporary
hide files = /~$*.doc?/~$*.xls?/~$*.ppt?
vfs objects = full_audit catia fruit streams_xattr
fruit:aapl = yes
full_audit:syslog = false
full_audit:prefix = %u|%I
full_audit:success = connect mkdir rmdir pread_send pread_recv create_file read
full_audit:failure = connect
security = user
include = /etc/samba/smb-null.conf
map to guest = bad user
kilbey1
Post by kilbey1 »
Also, rebooting the NAS solves the issue, if it makes a difference. The mounts lose connection after some time.
Reinstalling the system is the fastest solution.
You can also send an email to our support team and wait for remote processing: viewtopic.php?f=75&t=608
kilbey1
Post by kilbey1 »
Thanks, got stuck on "Loading..." graphic, but only because it took a long time to check the drive. Reset info, apps, etc. and I'm back in business. Appreciate the help.
Return to “File Services”
