Pi-Hole is a DNS for ad-blocking/privacy protection
https://pi-hole.net
pi-hole
Re: pi-hole
couln't you do this using the Docker features?
Re: pi-hole
I think I have got this working using docker compose.
You will need to:
Handy URL''s
I currently have this running on a Raspberry PI, I hope to be able to move this onto my TNAS.
Please feel free to post any questions or contact me regrading this.
Updates to follow.
You will need to:
- Create 2 folders. One for /etc/pihole, and one for /etc/dnsmasz.d.
- Pick 2 ports not in user to redirect port 80 and port 443 traffic (For this example I used 8085 and 503 to replace port 80 and 443).
- Determine your IP
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp"
- "8085:80/tcp"
- "503:443/tcp"
environment:
TZ: 'Europe/London'
ServerIP: <IP_OF_DEVICE>
volumes:
- '<PATH_TO_FOLDER>:/etc/pihole/'
- '<PATH_TO_FOLDER>:/etc/dnsmasq.d/'
restart: unless-stopped
- https://github.com/pi-hole/docker-pi-ho ... pabilities
- https://github.com/pi-hole/docker-pi-hole/
- https://docs.pi-hole.net/
Updates to follow.
Re: pi-hole
It may be best to run pi-hole with its own IP address in the same subnet as your main LAN.
This will avoid any port mapping issues, as all ports will be available.
You can follow this guide to create a network in docker that uses the same IP range as your LAN.
Just make sure any IP addresses you give to docker containers, are also listed as static/assigned IPs in your router, this will remove them from the DHCP pool, and your router won't try assigning the same IP address to another device.
The network created won't be available via the TOS Docker app, but will be available via Portainer.
Portainer, by the way, is far superior to the TOS Docker app for deploying containers.
When deploying via Portainer, you get a drop-down list to select the network, and can type in an IPv4 address of your liking.
- snapperheadjoeTM
Re: pi-hole
I was able to follow this video and successfully setup my "Pi-Hole" Docker instance on my TNAS F4-210. https://www.youtube.com/watch?v=XziNCmcxB_c
The walk through is straight forward and works perfectly. I run Unifi for my network infrastructure, so I point DNS on my USG to the IP of the Pi-Hold Docker instance and now all devices on my whole network are enjoying Pi-Hole Goodness! I have 90+ wired/wireless clients on my network including security devices, smart devices, TVs etc. and none are experiencing any issues.
I've had no issues with black or whitelisting so far. I work from home and VPN to my company and have not seen any issues.
