TNAS NextCloud 2FA Fails to meet PHP requirements
tracyw
Post by tracyw »
I'm trying to install 2FA for the included NextCloud app, but TOS is running an end-of-life version of PHP (7.1). 7.1 is no longer receiving support, and needs to be updated. I've tried updating via the Beta Apps, but it doesn't seem to affect anything with the actual installation of PHP. When will TOS be updated with the latest version of PHP (8.03 as of this post). If nothing else, give us the ability to update to stay on top of security patches. Is there an upgrade schedule for PHP updates?
F5-221
Re: TNAS NextCloud 2FA Fails to meet PHP requirements
PHP 7.2 and above are being tested and improved. If the testers think it can be used normally, you will be able to update it.
The PHP module in the application center is only applicable and configured to the web server and other required third-party applications.
The PHP module of TOS itself will not be modified.
If you want to update the PHP module inside TOS, a lot of adaptation work is required.
Return to “Others”
