services not start automatically
the web server, mariadb and smb services does not start automatically when the NAS is turned on
Re: services not start automatically
Do you mean that after restarting TNAS, the Web server, mariadb and smb services that have been enabled will no longer be available?
Can you describe the situation that cannot be used? Which version of your TOS is? Which model is your machine?
my TNAS model F2-210, TOS 4.2.08... No, what happens is that when I restart the TNAS the Webserver, Mariadb and Smb services are turned off and I have to restart them again.
Did you do anything before restarting? Under normal circumstances, this problem does not occur.
Can you try to reboot the device again and check the results?
I'm using the control panel startup and ignition timing
I have seen this also with time-machine and afp, I switched the nas f-2-210 off to move it and when it came back up afp and TM were not active and my Mac could not back up but it was ok and has backed up the previous night
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
Hi - I have the same problem.
Is there solution?
Rog
Is there solution?
Rog
