Disk space usage.
V8Triker
Disk space usage.
Post by V8Triker »
I am somewhat confused in disk usage.
I have a F5-221
First off I created a 3 drive RAID5, with 3x 3Tb drives.
I then transferred around 1.7Tb of data from my existing Ubuntu server.
TNAS reported 1.7Tb in the TNAS status window.
A day later, I created a RAID1 Volume with 2 x 2Tb drives.
I then copied 1.5Tb, of the data on Volumw#1, to Volume#2
This morning, when I checked on the unit I had suddenly gained 1Tb of data on Volume#1
When inspected, the two mounts seem to contain the same data, which is what I expected.
Can someone please explain the mismatch of just over a terabyte.
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
V8Triker
Re: Disk space usage.
Post by V8Triker »
Mkay, got a bit closer, but more confused.
The admin directory seems to be 1.1Tb. But there is not 1Tb in it.
This is also confirmed in the GUI
TNAS F5-221
1X WD 4TB USB
V8Triker
Post by V8Triker »
I think I may have found the culprit, considering usage is still increasing.
There seems to be a job zipping up the ServerFolders directory, which has been running for the last 22 hours.
root 7085 7033 0 Mar06 ? 00:00:00 sh -c cd '/usr/www/tos' ; /etc/zip.sh '/mnt/md0/public/ServerFolders' zip '/mnt/md0/User/admin/.data/temp/'
root 7086 7085 0 Mar06 ? 00:00:00 /bin/bash /etc/zip.sh /mnt/md0/public/ServerFolders zip /mnt/md0/User/admin/.data/temp/
root 7091 7086 90 Mar06 ? 21:41:51 /usr/bin/zip -q -r /mnt/md0/User/admin/.data/temp//ServerFolders.zip ./Home ./Multimedia ./Shared
root 7131 2 0 Mar06 ? 00:00:00 [md8_raid1]
root 7272 2 1 Mar06 ? 00:29:38 [md0_raid5]
Looks like I am gonna have to wait for it to complete, as the use of kill is not permitted :(
[admin@CABBAGE md0]$ kill 7086
-bash: kill: (7086) - Operation not permitted
TNAS F5-221
1X WD 4TB USB
V8Triker
Post by V8Triker »
So, I found out that it is possible to log in a root, (via SSH using the same password that you use for admin), and so kill the process.
All is good in the world again. :)
Hopefully this post will help other in the future.
TNAS F5-221
1X WD 4TB USB
May I know how you process the copy task? which file service did you use?
what other operation you did in your system?
V8Triker
Post by V8Triker »
TMroy wrote: 07 Mar 2021, 22:22 May I know how you process the copy task? which file service did you use?
The original copy was done my mounting the TNAS drive in my Ubuntu instance, the initiating the copy in a Webmin session.
I seem to recall that I accidently clicked "Download" when I was right clicking on the ServerFolders folder, in TNAS.
Despite cancelling the dialog, I am guessing it still initiated the Zip job, to prepare the files (1.5Tb) for download.
TNAS F5-221
1X WD 4TB USB
I see. Then the zipping task is running for download. we will try to add a new feature on GUI which allows you to cancel the download task.
V8Triker
Post by V8Triker »
TMroy wrote: 07 Mar 2021, 23:34 I see. Then the zipping task is running for download. we will try to add a new feature on GUI which allows you to cancel the download task.
Many thanks, for both your response and the future functionality.
TNAS F5-221
1X WD 4TB USB
Return to “File Services”
