list of compatible wifi dongles
Is the any list of compatible wifi dongles? The chipset RTL8812AU is very outdated and i'm not able to find any in amazon or any other reputable store.
Re: list of compatible wifi dongles
There is no other compatibility list for the time being,you can try this product: https://www.amazon.com/dp/B075689CL4
Is this the only compatible device or can I use any device that has a RTL8812BU or RTL8812AU chipset?
TMS
Currently only supports dual-band 1200M Gigabit USB wireless network card with Realtek RTL8812AU chip.
thanks for sharing
I want to suggest firefox vpn addon which I often use for protection my wifi and unlocking different websites. It works usually well without glitches. Plus it great solution for watching netflix.
