Weird screen after install TOS on new F4-422
TUNG.LE
Post by TUNG.LE »
New F4-422, with 3 Seagate wolf 12TB. After TOS is installed, I get this screen instead of Admin password setup screen (per installation video),
Any idea?
Create a Volume
Volume name
Description
Storage Pool
{{item['storage_name']['name']}}
RAID Type
{{default_config['storage_type']['name']}}
Capacity(GB)
{{default_config['storage_capacity']['name']}}
Free space(GB)
{{default_config['volume_capacity']['name']}}
Volume capacity(GB)
Max
Next
CreateStorage Pool
Please select hard drives to create RAID array
{{item.prefix}}{{item.sort}}
{{item.model}}
{{item.capacity}}
{{name}}
Free space
Data protected space
Unutilized space
Next
Create a Volume
Capacity(GB)
Free space(GB)
Volume capacity(GB)
Max
Back Next
Create a Volume
Select a file system
Btrfs
Ext4
Notes
Btrfs supports advanced features, including shared folder snapshots, replication, and better data protection.
Notes
This is a widely used file system in the Linux operating system.
Back Next
Create a Volume
Confirm settings
{{item.title}}
Back Next
Format RAID
The formatting will take about 3-20 minutes. Please do not cut off the power, pull or insert hard drives or refresh the page!
{{circle.process}}%
Re: Weird screen after install TOS on new F4-422
When installing the system, if there is no volume in the hard disk and the volume cannot be recognized, you need to create an array or storage pool first, and then create a volume in the storage pool.
Note: This will format the hard drive.
Return to “Initialization”
