Notice of new forum maintenance rules
Admin
Administrator
Post by Admin »
The TerraMaster Forum is one of the important ways for TerraMaster users to get help and support. It has been almost one year since the TerraMaster forum was launched, and the content of the forum is increasing rapidly. Recently, we have received complaints about the confusing content in the forum, not clear and orderly enough, so that accurate and useful information cannot be quickly found, which has caused some trouble to users.
In order to make the TerraMaster forum more tidy and orderly, and to provide users and visitors with more effective information and value,
before you decide to publish a new topic:
1. Visit the corresponding section or search to find out whether there is already content that is the same as the topic you plan to post;
2. Make sure your topic and content comply with the rules of this forum;
3. To get help quickly, make sure you have provided enough information about your issues;
4. Make sure your topic or thread is posted in the correct forum section; If it is posted in a wrong section, it will be removed and you need to create a new one in the right forum section.
The following topics will be deleted one week after the case is closed:
1. Repeated topics and contents;
2. The topic or content which does not match the actual situation;
3. There are already solutions to the issues raised in the topic;
The following topics will be deleted immediately:
1. Topic or contents that violate the rules of this forum;
2. Advertising;
3. Lack of specific issue description, just a topic expressing negative emotions;
The above rules will take effect immediately from the release. Thanks for your support!
Forum Administrator
yerc1
Re: Notice of new forum maintenance rules
Post by yerc1 »
TerraMaster staff should also follow the rules.
When someone asks something in a wrong thread, TM support should:
1. not try to resolve the question in that wrong thread,
2. instead, direct the user to go to the correct thread or ask them to create a new one if none exists.
I have seen this a few times but the latest example is viewtopic.php?f=28&p=10476#p10476
Thank you!
Actually we move such posts to the correct thread from time to time manually, but this is not the solution, it costs us a lot of works. so the user who violate our rule will be banned from any new post.
Miawhite
Post by Miawhite »
thank you for the rules
Tanveer6279
Pakistan
Post by Tanveer6279 »
Thanks for the clarification. Is there a recommended format or template for technical posts (model, firmware version, logs) to improve categorization and faster resolution? Also, will there be an Eligibility Check or validation step before posting to help prevent duplicate or incomplete technical threads?
Currently, there is no fixed format or template for posting. You can refer to the official operation guide and mark the model and the current system version at the beginning of the post. Except for specific sections, there are no restrictions on user posting at present. We will handle duplicate posts.
