HDDs with Power Disable feature
RobertB
Post by RobertB »
Do hard drives with the "power disable" feature work properly in the D2-310?
Thanks.
Re: HDDs with Power Disable feature
It can work normally on this product, and the recommended model can be found in the TDAS compatibility list: https://www.terra-master.com/global/compatibility/
RobertB
Post by RobertB »
Thanks for the response.
Return to “USB Series”
