SSD Cache
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
La Taupe
SSD Cache
Post by La Taupe »
I installed a WD Green 480GB SSD in my F5 422, it is well seen by TOS
but impossible to use it to cache, I have "------------" in the cache menu.
Best regards
F5 422
Re: SSD Cache
Can you add a screenshot as an attachment? You should be able to enable the SSD and select the partition to use.
La Taupe
Re: SSD Cache
Post by La Taupe »
{L_BUTTON_AT}TMRyan
F5 422
Re: SSD Cache
You can try to restart the device.
Enigma55
Re: SSD Cache
Post by Enigma55 »
I had the exact same problem and was told it was because I was running TOS 4.2.10 beta OS and this is a known issue. In order to fix it they want me to reinstall TOS from scratch and go back to 4.2.09. I haven't done that yet as I am afraid of losing my existing data though I've been told it will not be erased. Are you running the newest beta version of TOS also? My current setup was (3) 16TB drives in a RAID 5 config that always worked fine. I wanted to add a 4 Samsung 850 SSD and was unable to do so getting the same result that the original poster here did.
La Taupe
Re: SSD Cache
Post by La Taupe »
yes I confirm I am using TOS 4.2.10 beta because I have so many problems with 4.2.09 (SMB and FTP does not work well) problem of special characters (french) and forcing dates in FTP.
But 4.2.10 does not work better than 4.2.09.
At times I wonder if I should not put TrueNas to solve the problems.
And to answer the question, reboot does not change anything for the SSD.
F5 422
Re: SSD Cache
Please try switching to English to see if the cache can be set.
La Taupe
Re: SSD Cache
Post by La Taupe »
Same problem.
F5 422
Re: SSD Cache
Do you have another SSD to try? I afraid of that is a compatibility issue.
La Taupe
Re: SSD Cache
Post by La Taupe »
I don't have another SSD, but Enigma55 has the same problem as me and I think not with the same drive.
If it can confirm the brand of the SSD.
F5 422
Return to “Compatibility”
