So angry with TNAS
mpg732
So angry with TNAS
Post by mpg732 »
I have an Tnas F5-422 Running TOS Version 4.2.07-2012241608. I logged into the TNAS via FireFox. I navigated to a folder, selected a bunch of files to be deleted. I deleted the files. Navigated to the recycle bin. Saw all the files I just deleted. Emptied the recycle bin. Recycle bin was now empty. Went back to the same folder as before and all the files where still there. So I started looking at other folders to see if some thing else was deleted. Then found that another folder that contained a lot of files was now empty and the files where gone. These where files I did not have a back up yet and now I am screwed. So I hope you can understand why I am so angry.
titanrx8
Re: So angry with TNAS
Post by titanrx8 »
As a fellow user, sorry to hear this.
A couple of things.
I'm surprised you're using Firefox to get to the tnas desktop. When I try Firefox the screens don't work right. Like no scroll bars or other issues. I found that I have to use chrome and that's true whether I'm logging in from android or windows devices. Have you tried chrome?
Also were the files large/numerous. If I try manipulating files or directories from the tnas desktop I get a warning popup that the file action will be slow (maybe they should add unreliable to the warning) and recommends samba. So, I use samba from a win 10 machine and have had no issues. I've moved and deleted 10s of thousands of files using samba with no issues (the samba log was actually in the millions of records the last time I looked).
Hope this helps in the future.
mpg732
Post by mpg732 »
It was numerous files. I never got a warning to pop up and have so far no issues using Firefox...
sianderson
Post by sianderson »
titanrx8 wrote: 14 Feb 2021, 07:37 As a fellow user, sorry to hear this.
A couple of things.
interesting, Firefox is my browser of choice, i have never had any such issues from my W10 laptop
F2-424 TOS 7.0.1130
F2-423 TOS 7.0.1130
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Gandalf1369
Post by Gandalf1369 »
mpg732 wrote: 14 Feb 2021, 13:12 It was numerous files. I never got a warning to pop up and have so far no issues using Firefox...
See attached image. You probably, at some point, checked the box to stop showing the pop-up warning.
mpg732
Post by mpg732 »
I don't recall ever seeing that popup.
{L_BUTTON_AT}mpg732
Deleting the data in the recycle bin of a shared folder will not affect the data of other shared folders.
Have you done any operations on the lost file folder, such as backup, data synchronization, or mounting.
mpg732
Post by mpg732 »
Dont tell it will not effect other data when it did effect. No to your other questions. I unfortunately did not have that backed up. 95% backed up except for this one folder and its content. I can replace the data its just doing to take a lot of work to do so. Days of work.........
Have you done anything with this folder?
For example, using the mirror backup mode in USB Copy to transfer a folder in the USB to TNAS.
mpg732
Post by mpg732 »
NO I have not.
Return to “File Services”
