Connecting Windows PC to Thunderbolt Device
tomb_raider_fanatic
Post by tomb_raider_fanatic »
I have a PC with a USB Type-C v3.2 port on the back.
I bought a D5 Thunderbolt 3 enclosure thinking that the Thunderbolt connection would be backward compatible with USB-C.
When I connect it with a thunderbolt cable, windows finds the device, but will only install a Billboard Device driver.
When I tried to update the driver using the driver you supply, windows will not accept it.
So I also tried the RAID Manager PRO and it could not find the device (which did not surprise me given that I had trouble with the driver)
Is this all to be expected?
Do I have to fit a thunderbolt card to my PC in order to be able to use it?
Re: Connecting Windows PC to Thunderbolt Device
Hi, may I ask whether the transmission protocol of Type-C interface of your PC is Thunderbolt 3 or USB3.1?
D3 Thunderbolt3, D4 Thunderbolt3 and D8 Thunderbolt3
Device support Thunderbolt instead of USB.
tomb_raider_fanatic
The MSI spec says:
USB 3.1 Gen2 Type A+C
https://www.msi.com/Motherboard/MAG-Z39 ... cification
See back panel ports. item 8
Sorry!
D5 Thunderbolt 3 is a PC external device that does not support USB protocol connection. It can only be connected to the PC Thunderbolt 3 interface.
tomb_raider_fanatic
Ok, so I need to buy a thunderbolt card then, thanks
