TOS 4.2.10(x86) beta is released for testing
Important Notes
Beta version is an early version of a program or application that contains most of the major features, but is not yet complete, there may still be bugs. This version is released only to a select group of people, or to the general public, for testing and feedback. We do not recommend that you use the Beta version in your work environment.
Applicable models:
F2-220、F2-221、F2-420、F2-421、
F4-220、F4-221、F4-420、F4-421、
F5-220、F5-221、F5-225、F5-420、F5-421、F5-422、
F8-421、F8-422
Applicable TOS:
4.1.30 or later versions only. Not suitable for TOS 4.2.0X Beta!!!
Release Notes
This update includes following bug fixes for the previous version.
1. Update the Linux kernel version to 4.19;
2. Added WebDAV server function;
3. Added SMB file service advanced Settings;
4. Updated initboot version to V4.9.6;
5. Optimized user editing;
6. Optimized file sharing function of TOS;
7. Fixed an issue where HTTP and HTTPS could not redirect the page automatically after changing the port;
8. Modified array synchronization mode;
9. Modified the setting where non-admin user groups can access SSH;
10. Fixed an issue where the "Hardware and Power" in the control panel could not be used when the system language was Italian;
How to apply this new update?
1. Download the update package:
For X86 models: https://dl.terra-master.com/cn/TOS_S2.0 ... 051112.bz2
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
5. Clean your browser cache after update.
How to reinstall your TOS?
In case your update fails, and you may need to reinstall your TOS, follow the instructions below.
Download the installation package:
For X86 models: https://dl.terra-master.com/cn/TOS_S2.0 ... 051112.ins
1. Log in to TOS and go to TOS Desktop> Control Panel> General Settings> Update and Restore> Backup and Restore;
2. Tick "Backup system configuration" to back up your system configuration;
3. Go to TOS Desktop> Control Panel> General Settings> Update and Restore> Restore to Factory Default;
4. Tick "Restore to factory default", and then click "Apply"; your system will be erased, but the data on the hard drives will not be deleted;
5. Refresh the browser page, and follow guide on the page to install a new TOS;
6. If the page refresh fails, please use TNAS PC to search for your TNAS device; Then select the device and click "Login"; Follow the web page to install the new TOS;
7. After the system installation is complete, log in to TOS and go to TOS desktop> Control Panel> General Settings> Update and Restore> Backup and Restore to restore your backed up system configuration.
Issue report:
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.viewtopic.php?f=28&t=1560
tutuzik
Re: TOS 4.2.10(x86) beta is released for testing
Post by tutuzik »
web server does not turn on
sports_wook
Post by sports_wook »
Docker will not start, yet again, after updating to 4.2.10. Seems the new kernel does not like the Docker app.
It's getting extremely frustrating having to spend hours upon hours restoring, reconfiguring, etc. every time an update is released.
UncleJohnsBand
Post by UncleJohnsBand »
I am out of state remote....rdp'd into machine at home and run update... F5-221 now not reachable.... i guess it is now offline till I am back at home. 🙁
tutuzik
Post by tutuzik »
hardware power HARDWARE TAB EMPTY DOES NOT WORK
tutuzik
Post by tutuzik »
IT IS IMPOSSIBLE TO ENABLE THE WEB SERVER WHEN CHOOSING TO ENABLE THE WEB SERVER WRITES THE CONFIGURATION SAVED BUT THE SERVER DOES NOT TURN ON
drakey83
Post by drakey83 »
This update screwed up my Plex installation, it refuses to "start".
Dave11
Post by Dave11 »
After this update docker images removed and the docker service refuses to start from the GUI.
Gandalf1369
Post by Gandalf1369 »
drakey83 wrote: 09 Feb 2021, 07:05 This update screwed up my Plex installation, it refuses to "start".
Have you tried this: viewtopic.php?f=75&t=364 ??
Also, don't forget - this is a BETA version of the TOS.
UncleJohnsBand
Now that I am no longer remote I was able to reboot my TNAS F5-221. It came write back up running 4.2.10.
My OneDrive sync was not working. Was not able to set the Sync. Uninstalled. Re-installed and still am not able to set the Sync. It has the box for the Sync name.... but no matter what I put in I click Next and nothing happens. Effectively no OneDrive Sync is broken following the upgrade.
