Docker RPC Error containerd: container did not start be
Discussion about Docker
zpsal
Post by zpsal »
I've been having trouble connecting to containers initially via TCP but then tried with the docker command (docker exec -ti <ID> sh)
This is the error I'm receiving
[admin@TNAS-015ED4 ~]$ docker exec -ti 40915f75b173 ps
rpc error: code = 2 desc = containerd: container did not start before the specified timeout
[admin@TNAS-015ED4 log]$ tail -500 docker.log
time="2021-02-05T15:16:03.350875529-06:00" level=info msg="libcontainerd: new containerd process, pid: 8658"
time="2021-02-05T15:16:04.737902611-06:00" level=info msg="Graph migration to content-addressability took 0.00 seconds"
time="2021-02-05T15:16:04.738161666-06:00" level=warning msg="Your kernel does not support swap memory limit"
time="2021-02-05T15:16:04.738216667-06:00" level=warning msg="Your kernel does not support cgroup cfs period"
time="2021-02-05T15:16:04.738234236-06:00" level=warning msg="Your kernel does not support cgroup cfs quotas"
time="2021-02-05T15:16:04.738250540-06:00" level=warning msg="Your kernel does not support cgroup rt period"
time="2021-02-05T15:16:04.738266218-06:00" level=warning msg="Your kernel does not support cgroup rt runtime"
time="2021-02-05T15:16:04.738277477-06:00" level=warning msg="Unable to find blkio cgroup in mounts"
time="2021-02-05T15:16:04.738384948-06:00" level=warning msg="mountpoint for pids not found"
time="2021-02-05T15:16:04.738727439-06:00" level=info msg="Loading containers: start."
time="2021-02-05T15:16:05.322539328-06:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
time="2021-02-05T15:16:05.714791681-06:00" level=info msg="Loading containers: done."
time="2021-02-05T15:16:05.733048278-06:00" level=warning msg="failed to retrieve docker-runc version: unknown output format: runc version commit: 9c2d8d184e5da67c95d601382adf14862e4f2228\nspec: 1.0.0-rc2-dev\n"
time="2021-02-05T15:16:05.733232675-06:00" level=warning msg="failed to retrieve docker-init version: exec: \"docker-init\": executable file not found in $PATH"
time="2021-02-05T15:16:05.733525560-06:00" level=info msg="Daemon has completed initialization"
time="2021-02-05T15:16:05.733567512-06:00" level=info msg="Docker daemon" commit=89658be graphdriver=btrfs version=17.05.0-ce
time="2021-02-05T15:16:05.747051783-06:00" level=info msg="API listen on /var/run/docker.sock"
time="2021-02-05T15:16:33.082765914-06:00" level=warning msg="failed to retrieve docker-runc version: unknown output format: runc version commit: 9c2d8d184e5da67c95d601382adf14862e4f2228\nspec: 1.0.0-rc2-dev\n"
time="2021-02-05T15:16:33.082862341-06:00" level=warning msg="failed to retrieve docker-init version: exec: \"docker-init\": executable file not found in $PATH"
time="2021-02-05T15:16:39.492568801-06:00" level=info msg="Attempting next endpoint for pull after error: error unmarshalling content: invalid character '<' looking for beginning of value"
time="2021-02-05T15:20:06.829481486-06:00" level=error msg="Error running exec in container: rpc error: code = 2 desc = containerd: container did not start before the specified timeout"
time="2021-02-05T15:23:59.389126325-06:00" level=warning msg="failed to retrieve docker-runc version: unknown output format: runc version commit: 9c2d8d184e5da67c95d601382adf14862e4f2228\nspec: 1.0.0-rc2-dev\n"
time="2021-02-05T15:23:59.389227702-06:00" level=warning msg="failed to retrieve docker-init version: exec: \"docker-init\": executable file not found in $PATH"
time="2021-02-05T15:24:06.154997661-06:00" level=info msg="Attempting next endpoint for pull after error: error unmarshalling content: invalid character '<' looking for beginning of value"
time="2021-02-05T16:22:52.196984004-06:00" level=error msg="Error running exec in container: rpc error: code = 2 desc = containerd: container did not start before the specified timeout"
time="2021-02-05T17:04:49.968931327-06:00" level=error msg="Error running exec in container: rpc error: code = 2 desc = containerd: container did not start before the specified timeout"
I've uninstalled and reinstalled docker hoping it would redo everything from fresh, but it doesn't seem to work. I have two TerraMaster devices and this is only on one of them.
TMS
Re: Docker RPC Error containerd: container did not start be
Post by TMS »
zpsal wrote: 06 Feb 2021, 07:24 [admin@TNAS-015ED4 log]$ tail -500 docker.log
Show that the kernel does not support, can tell me what TOS system version you are using and the image name.
zpsal
Post by zpsal »
THat machine is a F5-221 using 4.2.08-2101111540.
zpsal
Post by zpsal »
It seems the container is running- if I build an SSH tunnel to the machine, and proxy my traffic over SOCKS5, I can bring up the Nextcloud session by going to http://172.17.0.1:7670/
But it's slow. Very slow.
It seems it's not forwarding ports and it's not letting me use docker exec to communicate with it.
Return to “Docker”
