[ SickChill ] Automatic Video Library Manager for TV Shows
About SickChill :https://sickchill.github.io/
Applicable models: TerraMaster x.64 series
Applicable TOS: 4.1.27 or later versions
Applicable TOS: 5.0.130 or later versions
App download: https://tmnascommunity.eu/download/sickchill
Required packages:
Python38 > 3.8.7.1
SickChill is a program that downloads your favorite TV shows, then processes and stores them in your library. And that all fully automated! Just set it up and as soon as there is a new episode released it gets downloaded. SickRage is your ultimate PVR.!
How does this all work?
When you add a show to SickRage the data (like air-dates, episode name/number) are pulled from an indexer like TheTVDb or TvRage. At that point SickRage knows when a new episode is going to air and starts the search on your favorite Torrent and/or NZB site. For this search you can set quality settings. For example: HDTV or SD quality. SickRage will go over all the results to find the quality YOU want and when found snatches the torrent/nzb and sends it to your download client. (sabnzb, utorrent, transmission etc.) At this point SickRage start monitoring your clients download folder to see if the file is finished downloading. When this is the case SickRage starts the post-processing. Here you can tell SickRage to move the file to your shows folder, or also rename it, or send notifications to Plex/Kodi or to your smart-phone. The list is long for what you can do with post-processing, simply set the actions you prefer. And this whole proses is completely automated. So once you set it up no user intervention is required. This makes SickRage ideal for NAS devices. But can run on almost every other device.
Features
SickRage contains a ton of cool features. Some of those are :
Automatic torrent/nzb searching, downloading, and processing at the qualities you want
Automatic subtitle downloads for your shows.
Supports Anime and Sports shows
Largest list of build-in torrent and nzb providers, both public and private
Possibility to add (almost) every NZB/Torrent provider with the custom provider option
Sends notifications to your media server/software and/or mobile/social devices
Can notify Kodi, XBMC, Growl, Trakt, Twitter, and many more when new episodes are available
Updates Kodi library, poster/banner/fanart downloads, and NFO/TBN generation
Configurable automatic episode renaming, sorting, and other post-processing
Easily see what episodes you're missing, are airing soon, and more
Searches TheTVDB.com, TVRage.com, and AniDB.net for shows, seasons, episodes, and metadata
Episode status management allows for mass failing seasons/episodes to force retrying
DVD Order numbering for returning the results in DVD order instead of Air-By-Date order
Allows you to choose which indexer to have SickRage search its show info from when importing
SickRage can easily tell if info for an existing show comes from TheTVDB or TVRage when importing
Automatic XEM Scene Numbering/Naming for seasons/episodes
Available for any platform, uses a simple HTTP interface
Specials and multi-episode torrent/nzb support
Improved failed download handling
DupeKey/DupeScore for NZBGet 12+
Real SSL certificate validation
Hardfecx
Re: [ SickChill ][ 1.00.00 ] Automatic Video Library Manager for TV Shows
Post by Hardfecx »
does it work with for example french or german stuff too?
Mordac85
Post by Mordac85 »
@Hardfecx yes, as long as the shows are listed with the indexer, thetvdb.com.
@Outkastm this doesn't seem to be updating. Is there a way to update it manually?
F5-221
TOS 5.1.67
4 x 4TB RAID5 EXT4
1 x 8TB EXT4
Re: [ SickChill ][ 1.20210723.0 ] Automatic Video Library Manager for TV Shows
Up to 1.20210723.0
chalnoth
Re: [ SickChill ][ 1.20210723.0] Automatic Video Library Manager for TV Shows
Post by chalnoth »
Any chance you can update the install package to 2022.2.17 as it has a few fixes that would be useful.
F4-422 - 4.2.15-2107221409 - VirtualBox, ModBase1, Python 3_8, Docker, Text Editor, iTunes Server, Plex Media Server, qBittorrent, ffmpeg
Hardfecx
Post by Hardfecx »
is it possible to get an arm version?
chalnoth wrote: 17 Feb 2022, 18:02 Any chance you can update the install package to 2022.2.17 as it has a few fixes that would be useful.
up to 1.20220217.0
Re: [ SickChill ][ 1.20220220.0] Automatic Video Library Manager for TV Shows
up to 1.20220220.0
chalnoth
Post by chalnoth »
Asking nicely for a TOS5 package... :D
cpeb
Post by cpeb »
Afternoon
Got Modbase and python installed before i installed sickchill but sickchill wont start.
Config file only has the webport in it and all the logfiles show the same message.
<br />
<b>Warning</b>:  fopen(/mnt/appdata/MOD_CONFIG/SickChill/DATA/Logs/sickchill.log): failed to open stream: No such file or directory in <b>/usr/www/modules/SickChill/www/4.php</b> on line <b>87</b><br />
TOSv4.2.39
Anyone able to point me in the write direction? All others custom apps working fine.
