should front LEDs be green when drives inside, but D5 not connected to a computer?
chasg
Post by chasg »
Hi All,
I have a D5 TB enclosure that I bought recently, and I have a question about the front LEDs:
If a drive is inside a slot, and the D5 enclosure is not connected to a computer, should the LED associated with that drive be red, or green?
You see, I can't connect this D5 to my M1 Mac Mini yet (drivers not up to date), so I can't see if it's actually working, but I find it strange that all the LEDs on the front stay red when I have drives inside. So this is making me wonder: is my particular enclosure defective?
In an attempt to test further, I plugged the D5 into a PC, but only into a USB 3 port (with a cable that has USB-C on one end, and USB-A on the other). No drives mounted, and all the LEDs stayed red. But this could be because the PC doesn't actually have thunderbolt, I just used an adaptor cable to connect the enclosure to a USB port. So not a reliable test.
I'm out of machines to test the D5 on, and I only have a short window in which to send it back. But I really need to know: should those red LEDs be green when drives are inside (or do they only turn red if the drives are being successfully mounted on a computer?).
Many thanks in advance for any help.
Chas
chasg
Re: should front LEDs be green when drives inside, but D5 not connected to a computer?
Post by chasg »
Hi, thanks for your reply.
My Mac is an M1 Mac Mini, so the enclosure won't work on it, until the drivers are updated. But I didn't install a driver on the PC I was testing with, I'll do so, thanks for the reminder.
But can you tell me: if the enclosure is not connected to a computer, should the LEDs on the front be green for any installed hard drives? Or do they stay red until any installed hard drives are mounted on a connected computer?
At the moment, I have one drive inside (enclosure is not connected to a computer), and its associated LED is red.
When the D5 Thunderbolt 3 device is not connected to the Thunderbolt 3 cable, the LED is red, the LED is red after sleep, and the green LED is blinking during normal reading and writing.
In addition, D5 Thunderbolt 3 devices do not support USB protocol interface connection, only D5 Thunderbolt 3 interface connection. Regarding the Mac OS M1 chip driver, we are in the stage of development and testing.
chasg
Post by chasg »
That is very helpful information, thank you very much.
I will wait (patiently!) for the new driver to come. If you need testers (I'm running an M1 Mac Mini, OSX 11.2), just let me know.
