NAS hard locks when using NFS
lexman
Post by lexman »
I have a F2-422 running RAID 1 BTRFS. When sharing a newly created directory out over NFS only, the NAS will hard lock after some minutes of copying data at full line speed.
The hard lock means that the device will not response to any network traffic or to any power off command using the power button.
This is a very serious problem for me
Re: NAS hard locks when using NFS
Please try disable the DoS feature from Control panel > General settings > Security > DoS protection, that make any difference?
lexman
Post by lexman »
DoS protection was not enabled.
I have tried disabling all other services, manually setting IP addresses, disabling NFS4.1, reinstalling TOS by doing a factory reset
Return to “Network”
