MegaDisk
Kralomax
MegaDisk
Post by Kralomax »
When I was researching this product I saw that MegaDisk was supported so I purchased a F2-210. Come to find out I can't use MegaDisk and am getting an "Operation Failed" when trying to make connection. I did some research and can't find any ports that require opening for Mega or any other solutions. Does anyone have a solution for this problem?
https://hosting.photobucket.com/images/ ... fit=bounds
Re: MegaDisk
Please check if your username and password are correct and the network is normal
Kralomax
Re: MegaDisk
Post by Kralomax »
The app goes directly to create connection and won't let me proceed. (please see the attachment) I know my account is created because it will not let me duplicate it again. My username and password are the same as that created with MegaDisk. Thank you for your help.
Re: MegaDisk
Please check the network. Have you opened other network agents? Can you go directly to https://mega.nz/start using the current network? You can try to connect several times.
Kralomax
Re: MegaDisk
Post by Kralomax »
Are you asking if I can open mega through my browser? Yes I can. I have no problems with Dropbox or Google Sync, I just can't enter MegaDisk.
After completing this and hit "Confirm" I get an "Operation Failed!" reply.
Thank you again.
Re: MegaDisk
You can check if your mega account refuses to connect with other devices.
Can you try to log in with another mega account or computer?
Do you need to turn on a proxy server when logging into mega in your browser? If necessary, you need to enable the proxy server in the network settings in the control panel.
Kralomax
Re: MegaDisk
Post by Kralomax »
I can login to Mega, Google Drive, Drop Box, and OneDrive using my browser just fine.
I can login to Google Drive, Drop Box, and OneDrive through the TOS desktop, but can't login to Mega. (see the pic below).
I don't use any kind of proxy on my browser. I have tried on Chrome, Firefox, and even Brave with no success.
Thank you again for your time.
Re: MegaDisk
Hi
Can you try to create a connection with another account?
moyomoyuno
Spain
Re: MegaDisk
Post by moyomoyuno »
I had the same issue, you have to disconnect 2 factor authentication from your account. It seems that the application does not support this yet.
Re: MegaDisk
{L_BUTTON_AT}moyomoyuno
Can't you create a connection? Can you describe your problem in detail? The application can be used normally.
Return to “CloudSync”
