NAS won't automatically connect to WiFi on startup
gobending
Post by gobending »
Hi. I have a Terramaster F2-221, and I bought a WiFi dongle (RTL8812B chipset) to use it via WiFi. I can connect to my WiFi network with no trouble, and even if I disconnect the Ethernet cable, the NAS stays connected via WiFi. The problem is that, when I turn the NAS off and then turn it on again, it won't automatically connect to the WiFi network on startup and I can't access it, so I'm forced to plug the Ethernet cable, access the NAS through the local IP, and then disconnect the cable. Is there a way to make it to automatically connect wirelessly?
Re: NAS won't automatically connect to WiFi on startup
Sorry for the inconvenience caused to your use. There is no way to make it automatically connect wirelessly after restarting. We have solved this problem and will add it in a future version.
gobending
Post by gobending »
Thank you so much :)
Return to “Network”
