Drive temp warnings
rngrpower
Drive temp warnings
Post by rngrpower »
I keep getting drive temp warnings dated for the next day and saying drive temp is 55C or higher although checking in TOS at the status and temp shows only 39C. Changed fan settings to hi but still getting warnings.
TMS
Re: Drive temp warnings
Post by TMS »
hi,
What type of disk are you using? please refer to this link to check whether the disk is healthy:viewtopic.php?f=75&t=1125
This link is our recommended compatible hard disk: https://www.terra-master.com/global/compatibility/
You may also connect a USB drive to your TNAS. your USB drive temp is over heat.
Return to “System Resources”
