[ Sabnzbd3 ] Usenet Grabber
Re: [ Sabnzbd3 ][ 3.6.0.0 ] Usenet Grabber
Added TOS5 version
Daywalker
France
Post by Daywalker »
outkastm wrote: 18 Jul 2022, 07:17 Added TOS5 version
I successfully installed python38 and sabnzbd3 on my tos 5.0.130 nas but i can't activate sabnzbd3.
F5-422
What is the message on frontend ui, is it running or is stopped ?
Check if your Volume1 is healty, check the installed location in App Settings
Try to download again the tpk file and install it
Daywalker
France
Post by Daywalker »
{L_BUTTON_AT}outkastm
it's ok now, i uninstall sab and install again
F5-422
PriestyUK
Post by PriestyUK »
Update Available 3.7.0
Re: [ Sabnzbd3 ] Usenet Grabber
up to 3.7.1.0
vmadman
Post by vmadman »
Whenever I install Sabnzbd4, no icon ever appears on the desktop. When I open the app in Software Center and click "Enable", I get an "operation failed". How can I view the logs to see why it failed?
Also, when I try to download Sabnzbd3, I get an error that says "No file attached with the package!"
Please help. Thanks.
highgrade
Post by highgrade »
I have the same issue with enabling Sabnzbd
Make sure all the dependencies are installed.
highgrade
Post by highgrade »
I was able to resolved I installed version 4
