[ Sabnzbd4 ] Usenet Grabber
About :
Applicable TOS5: 5.0.130 or later versions
Applicable TOS6: 6.0.420 or later versions
App download: https://tmnascommunity.eu/download/sabnzbd4
Required packages:
Python310 > 3.10.5.1
TOS5 & TOS6: click on Support & Help from app description inside the App Center
What is it?
http://sabnzbd.org
SABnzbd is an Open Source Binary Newsreader written in Python.
It's totally free, incredibly easy to use, and works practically everywhere.
SABnzbd makes Usenet as simple and streamlined as possible by automating everything we can. All you have to do is add an .nzb. SABnzbd takes over from there, where it will be automatically downloaded, verified, repaired, extracted and filed away with zero human interaction.
Integrates with other tools
Apps like Sonarr, Sickrage, CouchPotato and Headphones can integrate with SABnzbd and automate your download process.
SABnzbd can also read and process RSS feeds, activate custom scripts and notify you via mail, growl, prowl, pushover and pushbullet.
Re: [ Sabnzbd3 ][ 3.2.1.0 ] Usenet Grabber
updated to 3.2.1.0
Re: [ Sabnzbd3 ][ 3.3.1.0 ] Usenet Grabber
updated to 3.3.1.0
Re: [ Sabnzbd3 ][ 3.4.0.0 ] Usenet Grabber
up to 3.4.0.0
Re: [ Sabnzbd3 ][ 3.4.1.0 ] Usenet Grabber
up to 3.4.1.0
Re: [ Sabnzbd3 ][ 3.4.2.0 ] Usenet Grabber
up to 3.4.2.0
Re: [ Sabnzbd3 ][ 3.5.0.0 ] Usenet Grabber
up to 3.5.0.0
Re: [ Sabnzbd3 ][ 3.5.1.0 ] Usenet Grabber
up to 3.5.1.0
Re: [ Sabnzbd3 ][ 3.5.3.0 ] Usenet Grabber
up to 3.5.3.0
Re: [ Sabnzbd3 ][ 3.6.0.0 ] Usenet Grabber
up to 3.6.0.0
