[ Sonarr ] Smart PVR for newsgroup users
About : https://sonarr.tv
Applicable models: TerraMaster x.64 series
Applicable TOS5: 5.0.135 or later versions
App download: https://tmnascommunity.eu/download/sonarr
Required packages:
mono > 6.12.0.122.0
ModBase1 > 1.00.10.1
http(s)://yournasip:port/modules/Sonarr/www
About:
NZBDrone is a PVR for newsgroup users. It can monitor multiple RSS feeds for new episodes of your favourite shows and will grab, sorts and renames them.
It can also be configured to automatically upgrade the quality of files already downloaded if a better quality format becomes available.
Calendar
See all your upcoming episodes in one convenient location.
Manual Search
Find all the releases, choose the one you want and send it right to your download client.
Automatic Failed Download Handling
Sonarr makes failed downloads a thing of the past. Password protected releases, missing repair blocks or virtually any other reason? no worries. Sonarr will automatically blacklist the release and tries another one until it finds one that works.
Works great and looks even better doing it.
Notifications and fully customizable quality profiles.
Multiple Series views.
Re: [ Sonarr ][ 3.0.6.1265.0 ] Smart PVR for newsgroup users
Updated to 3.0.6.1265.0
Re: [ Sonarr ][ 3.0.6.1342.0 ] Smart PVR for newsgroup users
up to 3.0.6.1342.0
Kakise
Post by Kakise »
Both version don't want to start, there's no config folder and no logs :/
Tested on F2-221
Do you have also latest mono and ModBase1 apps installed?
Kakise
Post by Kakise »
Yes, after a clean reinstall & factory reset everything worked, thank you !
Re: [ Sonarr ][ 3.0.8.1507.0 ] Smart PVR for newsgroup users
up to 3.0.8.1507.0
Gandalf1369
Post by Gandalf1369 »
Any chance of getting a TOS5 version?? Thank you.
Will be done asap
Gandalf1369
Thanks @outkastm . . .
Just realized I should have also included a TOS5 version of "mono" in my request . . .
Thanks for all you do.
