[ Python38 ][ 3.8.12.1 ] Programming Language
About : https://www.python.org
Python 3.8.x branch release
Last version: 3.8.12.1
Applicable models: TerraMaster x.64 series
Applicable TOS5: 5.0.130 or later versions
App download: https://tmnascommunity.eu/download/python38
http(s)://yournasip:port/modules/Python38/www
The package is using the hashed certificates from TOS and fall back to bundle root certificate pulled from https://curl.se/ca/cacert.pem
The bundle root certificate will be pulled when NAS is rebooted or the Python38 is started manually.
And only if the local one available at /mnt/appdata/MOD_CONFIG/SSL_certs/cacert.pem is older than the remote one
Re: [ Python3 ][ 3.8.7.1 ] Programming Language
updated to 3.8.7.1
iago1460
Post by iago1460 »
Many thanks, seems to work well, only thing will be if it's possible to add it automatically to the path, seems to be only on /mnt/md0/application/Python38/sys/bin/python3
Is not difficult to add it in the path, but do you really need this ? Do wyou want to start it from CLI ?
This package is used as based for other packages that depend on it, which are started automatically from WebUI
simple way create a symbolic link in /usr/bin
ln -sf /usr/local/Python38/sys/bin/python3 /usr/bin/python3
then run with
python3
Re: [ Python3 ][ 3.8.7.3 ] Programming Language
Updated to 3.8.7.3
Also is added automatically in PATH if the app is started
Re: [ Python3 ][ 3.8.12.1 ] Programming Language
up to 3.8.12.1
Re: [ Python38 ][ 3.8.12.1 ] Programming Language
Added TOS5 version
franco72
Post by franco72 »
Not installed on TOS 5.0.152 :?
Gandalf1369
Post by Gandalf1369 »
May sound silly but make sure you are installing the TOS5 version. I'm running 5.0.152 and have Python38 (3.8.12.1) up with no problems. Perhaps a re-install . .
