[ mono ][ 6.12.0.122.0 ] Microsoft's .NET Framework
About : http://www.mono-project.com
Last version: 6.12.0.122.0
Applicable models: TerraMaster x.64 series
Applicable TOS5: 5.0.135 or later versions
App download: https://tmnascommunity.eu/download/mono
Required packages:
http(s)://yournasip:port/modules/mono/www
About :
Mono is a software platform designed to allow developers to easily create cross platform applications part of the .NET Foundation.
Sponsored by Microsoft, Mono is an open source implementation of Microsoft's .NET Framework based on the ECMA standards for C# and the Common Language Runtime. A growing family of solutions and an active and enthusiastic contributing community is helping position Mono to become the leading choice for development of cross platform applications.
Re: [ mono ][ 6.12.0.122.0 ] Microsoft's .NET Framework
updated to 6.12.0.122.0
ViliamVolosV
Post by ViliamVolosV »
{L_BUTTON_AT}outkastm
Hi - can you compile arm version. I then can test it on my arm device
i will try, will let you know when is ready
added TOS5 version
bhook
Post by bhook »
How can we upgrade the mono certificate?
bhook
Post by bhook »
Found the answer;
navigate to: /usr/local/mono/sys/bin/
run: ./cert-sync /etc/ssl/certs/ca-certificates.crt
