[Ubiquiti UniFi] UniFi Controller Management
About : https://www.ubnt.com/enterprise/#unifi
Applicable models: TerraMaster x.64 series
Applicable TOS5: 5.0.130 or later versions
App download: https://tmnascommunity.eu/download/unifi
Required packages:
OpenJDK11
http(s)://yournasip:port/modules/UniFi/www
The default device inform port is 8090. This can be always change from config[/color]
unifi.http.port=8090
About :
SOFTWARE
The central UniFi®Controller conducts device discovery, provisioning, and management of the UniFi Security Gateway and other UniFi devices through a single, intuitive interface.
Install, configure and manage your Wi-Fi devices with one easy‑to‑learn interface.
Manage Your Networks from a Single Control Plane
The UniFi®Controller can be accessed through any device using a web browser. A single UniFi Controller running in the cloud can manage multiple sites: multiple, distributed deployments and multi-tenancy for managed service providers.
Intuitive and Robust Configuration, Control and Monitoring
The UniFi® Controller enables the administrator to instantly provision and configure thousands of UniFi APs, allowing for quick, simple management of system traffic.
Remote Firmware Upgrade
Save time and effort by remotely upgrading device firmware.
Users and Guests
Keep track and control access of specific users and guests connected to your network(s).
Guest Portal/Hotspot Support
Easy customization and advanced options for Guest Portals include authentication, Hotspot setup options and the ability to run as an external portal server. Take advantage of UniFi’s rate limiting for your Guest Portal and Hotspot package offerings. Apply different bandwidth rates (download/upload), limit total data usage and limit duration of use — all with billing integration and voucher-based authentication.
Re: [Ubiquiti UniFi][ 6.2.26.0 ] UniFi Controller Management
updated to 6.2.26.0
Charlie_Croker
Re: [Ubiquiti UniFi][ 6.5.55.0 ] UniFi Controller Management
Post by Charlie_Croker »
Not working on TOS5 :( Will it be updated?
Hardfecx
Post by Hardfecx »
Is it possible to get an ARM Version of it?
Charlie_Croker wrote: 08 Mar 2022, 21:28 Not working on TOS5 :( Will it be updated?
To create .tpk package for TOS5, TM need to make public the packaging tool. I don't have it yet thus I cannot make any app for TOS5
Charlie_Croker
outkastm wrote: 08 Mar 2022, 22:20
Thanks for the info, Hopefully they will release the Packaging tool. Also a version of MAME would be cool, as I could use HDMI to create a dedicated Retro arcade machine. (I did this with my QNAP TS 453A and its cool)
