Limit Time Machine Backup Size
Time machine backup for macOS users
StephenM
Post by StephenM »
Is there any way I can limit the size of the time machine backups either as a total or per user?
StephenM
Re: Limit Time Machine Backup Size
Post by StephenM »
So I started from scratch.
For info: F4-210, with btrfs
I scrapped the shared folders and added one share for each Time Machine backup vault per Mac.
On the shared folder I set the quota to a suitable size.
I then set up the time machine in Backup and selected the folders to be used.
I then, on a Mac, selected one of the shared folders as a backup disk.
However, Time Machine sees that folder as the full size of the volume the shared folders are in. I suspect that will cause a time machine backup to fail if the NAS enforces the quota, but I don’t even know if the quota is applied to the folder.
How do I verify that the quota has been applied?
How do I make the quota size visible as the size that Time Machine has available to it?
StephenM
Post by StephenM »
I’ve also tried adding a vol size limit in etc/afp.conf
I know that this get overwritten when afp starts but I tinkered with some of the scripts in /etc/init.d to stop this from being overwritten.
This time the Time Machine on the Mac reported the size of the drive as set by the vol size limit.
However, as the backup continued the available space didn’t decrease. This could be because I’m running Catalina and it doesn’t save a backup as a sparsebundle but as a backupbundle instead.
Next test is to either symlink or hardlink a file name of type sparsebundle to see if that reports the correct free space.
I’d rather not have to break the init scripts to do this though. They’ll need breaking again after each TNAS update.
Can I put in a request that there is an option in setup to present to Time Machine a volume size.
Otherwise Time Machine will start failing backups using an unreported quota setting or if left unchecked the backups will fill up the whole of the hard drive over extended time.
StephenM
Post by StephenM »
This is a much needed feature and I can tell the developers what needs to be done - it should be relatively simple:
Use quota that is set on a share to populate the vol size limit parameter in afp.conf
Or
Have the option in the Time Machine setting in the Backup App to add a size limit there.
Modify /sbin/svrcfg-all -c afp to add the size limit into afp.conf.
Have an occasional cronjob that looks for .backupbundle in the Time Machine directories and make a symlink to for every backupbundle to a sparsebundle if the sparse bundle doesn't exist.
Happy to start a dialogue
We shall be glad to refer to your ideas and methods. Thank you!
macmpi
Post by macmpi »
{L_BUTTON_AT}StephenM
FYI, this feature has been discussed here for a while. Was expected for 4.2
Return to “Time Machine”
