Is this supported?
If so are there any blu ray devices that are compatible?
F4-210 USB Optical Drive
- sianderson
- Silver Member
Re: F4-210 USB Optical Drive
i guess nothing stopping you from just putting a USB extension cable and then use USB flash drives?
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
I was considering using the makemkv docker app, which needs access to the optical block devices in /dev/
Obviously a non starter now.
Not really sure if the driver of your optical drive is ready in the system.
