How to install MediaWiki in Docker?
Discussion about Docker
MediaWiki is a world-renowned open source wiki program that runs in the PHP+MySQL environment. The biggest role of MediaWiki is to archive knowledge, which can be used to build enterprise/personal knowledge bases.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
ARM models: F2-210, F4-210.
Compatible TOS version:
X86_TOS_4.1.30 and above, ARM_TOS_4.1.32 and above.
Instructions:
1. Input mediawiki at Registry under Docker to search and download the suitable image.
2. Check the downloaded image and click Launch.
3. Go to Container - Details- Overview to find the tcp port as the following picture shows:
4.Input TNAS IP address:9102(such as http://10.18.15.103:9102/) to use it.
Return to “Docker”
