Advertised as 10GB, received with 10GB port covered and "1000Mbps LAN" written on the side of the box.
How could this be?
Received F2-422 with 10GB port covered
Re: Received F2-422 with 10GB port covered
The product consists of three network ports: two 1000Mbps and one 10GbE.
{L_BUTTON_AT}hazza26
OK, but the covered 10Gb port indicated to me that it was not usable. Do I need to remove the metal covering it?
would you please also show the lable on bottom of your device? and your order bill too please, I want to make sure the model was not mixed with another one. thank you
Sure, here you go..
OK great, if the socket is underneath I will remove the cover myself and take you up on your kind offer. Thanks
