How to install DDNS-GO in Docker?
Discussion about Docker
DDNS-GO is a simple and easy-to-use tool to manage DDNS dynamic domain name which can automatically update the domain name to resolve to the public IP. Currently it supports AliDNS (Ali Cloud), DNSPod (Tencent Cloud), and Cloudflare.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
ARM models: F2-210, F4-210.
Compatible TOS version:
X86_TOS_4.1.30 and above, ARM_TOS_4.1.32 and above.
Instructions:
1. Input ddns-go at Registry under Docker to search and download the suitable image.
2. Check the downloaded image and click Launch.
3. Go to Container - Details- Overview to find the tcp port as the following picture shows:
4.Input TNAS IP address:46379 (such as http://10.18.8.113:46379/) to use it.
Return to “Docker”
