OneDrive Sync Issues
WaggersR
Post by WaggersR »
F2-221 running TOS 4.2.07 -2012241608
I've setup OneDrive Sync and the contents of my OneDrive synced successfully to my F2-221. However, any file or folder changes made on my PC or my F2-221 wont sync.
If I disconnect and reconnect, changes to OneDrive in the cloud will sync to the F2-221. File or folder changes on the F2-221 will not sync to the cloud.
The sync I've created on OneDrive Sync is setup as 'bidirectional'. Nothing is showing in OneDrive Sync's log file since the initial downloads when the task was created.
If someone could give me tips to troubleshoot this, I'd be very grateful.
Re: OneDrive Sync Issues
Thank you for your feedback. We are fixing this problem. A new version will be released after the test passes.
Have a great day!
Skywalker
Post by Skywalker »
hi - im trying to setup onedrive sync but when I login to my onedrive I get operation failed message. Is this a related issue?
{L_BUTTON_AT}Skywalker
The connection may encounter some problems.
When it prompts that the operation has failed, you immediately click "Next" to connect again, and you can usually connect.
Return to “CloudSync”
