SSL Port Error
McAwesome
SSL Port Error
Post by McAwesome »
When I try to set the SSL port to 443 for the WebServer I get an error:
Port 443 has been occupied
Also, how can I install an SSL certificate?
Re: SSL Port Error
There are many ports in the background, and it is normal that some ports are occupied.Port 443 is occupied, you can set and use other ports.
You can go to the control panel to import your SSL certificate, as shown below:
McAwesome
Re: SSL Port Error
Post by McAwesome »
