Can't enter MySQL using default username and password for MariaDB with F2-210
Using Web Server, PHP, MySQL, MariaDB.
renj86
Post by renj86 »
I cannot enter the MySQL server using MariaDB on F2-210 that I newly bought. MariaDB is the first application that I installed.
I have used username root and password admin but they don't work. These are the default user name and password from MariaDB.
I haven't changed other settings.
Please help.
Re: Can't enter MySQL using default username and password for MariaDB with F2-210
Please manually change the password and try again.
renj86
Post by renj86 »
I thought the default password was ok. Yes, after changing the password, it now seems working. Thanks!
juan26felipe
Post by juan26felipe »
Hello, install mariabd to be able to connect nextcloud, when assigning the user and the password it never works. It always gives a timeout error, someone from support can help me solve the problem, I clarify that the password has already been updated
Return to “Web Server/PHP/MySQL/MariaDB”
