Run Script at startup
fabiobiscia
Post by fabiobiscia »
Hi everyone. I would like to create a script that starts automatically on startup, possibly with root privileges. I have already tried some techniques tested with the main linux distros but none worked, could you help me? :shock:
Re: Run Script at startup
You can try to put the script under /etc/init.d/, and then use the touch command to create a file with the same name as the script under /etc/sc.d/.
Have a good day!
fabiobiscia
Thanks for the reply. in rc.d it is sufficient to create an empty file with the same name?
mil_house23
Spain
Post by mil_house23 »
hello, have the same problem, can you resolve?
i try the the solution but didnt work , i need to run java problem and keep running
Can you helpme please...
Nicolas
