How to install CouchPotato in Docker?
Discussion about Docker
CouchPotato is a free movie resource search engine which supports subtitle downloading and BT torrent downloading.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
ARM models: F2-210, F4-210.
Compatible TOS version: TOS 4.1.31 and above.
Instructions:
1. Input CouchPotato at Registry under Docker to search and download the suitable image.
2. Check the downloaded image and click Launch.
3. Go to Container - Details- Overview to find the tcp port as the following picture shows:
4.Input TNAS IP address:20897 (such as http://10.18.8.98:20897/) to use it.
Return to “Docker”
