TerraMaster F2-221 ddr4 ram compatability
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
Liam8828
Post by Liam8828 »
Hi
I recently bought this with the 2gb ddr4 ram installed and before i populate it with my drives i was looking to add another stick of ram.
I asked the support function but wasn't told the details of the ram i required but that it was out of stock.
Does anyone know what speed and size of ddr4 ram would work well please?
Dennis_H
Re: TerraMaster F2-221 ddr4 ram compatability
Post by Dennis_H »
I used this on my F2-221 and it seems to work fine. 8gb instead of 2.
https://www.amazon.com/gp/product/B006Y ... UTF8&psc=1
Tricky
Post by Tricky »
A friend used 8 gig of DDR3 in his F5-221 and its works fine...and way cheaper.
https://www.windowscentral.com/best-ram ... f2-221-nas
https://www.aliexpress.com/item/32617292005.html
Dennis_H
Post by Dennis_H »
Dennis_H wrote: 06 Jan 2021, 02:54 I used this on my F2-221 and it seems to work fine. 8gb instead of 2.
Edit... this is an 8gb stick, I meant 8 additional (10gb total) and it detects it and runs fine. Not really doing anything more than a fileserver so far though.
Liam8828
Post by Liam8828 »
So you have 2 gb of ddr4 and 8gb of ddr3?
Dennis_H
Post by Dennis_H »
If the built in 2 really is DDR4, then yes, that is what I have. I have had no issues and it reports 10Gb of RAM.
erik.meuwese
Post by erik.meuwese »
Compatibility list on https://www.terra-master.com/global/compatibility/ lists for F2-221 DDR3L 1600Hz 1.35V so DDR3 and DDR4 are not going to work.
Dennis_H
Post by Dennis_H »
The one I linked to is
Crucial 8GB Single DDR3/DDR3L 1600 MT/S (PC3-12800) Unbuffered SODIMM 204-Pin Memory - CT102464BF160B
and it works fine.
Return to “Compatibility”
