Album Backup
statekieto
Album Backup
Post by statekieto »
I have made an "album backup" by using default default folder of TNAS mobile app.
It seems that the content of the backup is in "admin>Mobile backup>" but, how can access to the folder from the File Manager?
Regards
statekieto
Re: Album Backup
Additional info:
I did not realize that "admin" folder is visible in the Mobile app but it is not visible using File Manager.
Is there any option to visualize the user folder?
Re: Album Backup
Try go to control panel》user》more》advanced settings, select the enable user home directory,then click apply.
You will be able to see the personal folders in the file management
