how would i drag stuff from the terrmaster nas to a 12tb externa hardrive i have connected to it via its rear usb 3 port
i wan to get all my stuff off this nas so i can scrap it
ive spent weeks trying to fix it and getting up early to let the makes connect to my pc only for them to have no clue at all
i was told if i bought cheap id end up buying twice so ill dump this nas and buy a synologhy or Qnap
External hd connected to Terrmaster
Re: External hd connected to Terrmaster
You can install an app called USB Copy, this app will help a lot to move your data from nas to your external hdd.
- sianderson
- Silver Member
as a one off thing you can just use the built in file manager and copy and paste from a shared folder on the nas to a folder on the USB share
there is no need to install extra software
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
